Import of WSJT .adi ~ EA8DR State of TF..??
G8LIY
Post by G8LIY »
I imported a WSJT .adi into Log4OM v2.11
The station "EA8DR" appears to be in the State of TF, in the QSO detail, the State drop down contains Tenerife or Las Palmas, unable to change to Blank
There is nothing in the original .adi that I can see to cause this, it shows TF in Log4OM adi
I have checked other "EA8" QSO's, the State is "Blank", But the drop down shows: Tenerife or Las Palmas
Thanks... 73 Dave
Original WSJTX adi
ADIF Export from ADIFMaster v[3.3]
http://www.dxshell.com
Copyright (C) 2005 - 2020 UU0JC, DXShell.com
File generated on 22 Feb, 2021 at 01:05
<ADIF_VER:5>3.1.0
<PROGRAMID:10>ADIFMaster
<PROGRAMVERSION:3>3.3
<EOH>
<call:5>EA8DR <gridsquare:3>IL8 <mode:3>FT8 <rst_sent:3>-15 <rst_rcvd:3>-15 <qso_date:8>20210225 <time_on:6>165945 <qso_date_off:8>20210225 <time_off:6>170915 <band:3>17m <freq:9>18.101126 <station_callsign:5>G8LIY <my_gridsquare:6>IO83SM <tx_pwr:3>2.5 <comment:25>FT8 Sent: -15 Rcvd: -15 <eor>
Log4OM adi
# Log4OM 2 by IW3HMH version 2.11.0.0
# http://www.log4om.com
# created: 01 March 2021
<ADIF_VERS:5>3.1.0 <PROGRAMID:7>Log4OM2 <PROGRAMVERSION:8>2.11.0.0 <eoh>
<ANT_AZ:1>0 <ANT_EL:1>0 <STATE:2>TF <BAND:3>17m <CALL:5>EA8DR <COMMENT:25>FT8 Sent: -15 Rcvd: -15 <CONT:2>AF <COUNTRY:10>Canary Is. <CQZ:2>33 <DISTANCE:7>3020.02 <DXCC:2>29 <EQSL_QSL_RCVD:1>R <EQSL_QSL_SENT:1>R <FREQ:9>18.101126 <GRIDSQUARE:6>IL18qj <ITUZ:2>36 <LOTW_QSL_RCVD:1>N <LOTW_QSL_SENT:1>R <MODE:3>FT8 <MY_COUNTRY:7>England <MY_DXCC:3>223 <MY_GRIDSQUARE:6>IO83sm <MY_RIG:5>X5105 <STATION_CALLSIGN:5>G8LIY <PROGRAMID:7>LOG4OM2 <PROGRAMVERSION:8>2.11.0.0 <QSL_RCVD:1>R <QSL_RCVD_VIA:1>E <QSL_SENT:1>R <QSL_SENT_VIA:1>E <QSO_COMPLETE:1>Y <QSO_DATE:8>20210225 <QSO_DATE_OFF:8>20210225 <RST_RCVD:3>-15 <RST_SENT:3>-15 <SWL:1>N <TIME_OFF:6>170915 <TIME_ON:6>165945 <TX_PWR:3>2.5 <MY_ANTENNA:7>MagLoop <QSO_RANDOM:1>Y <SFI:1>0 <QRZCOM_QSO_UPLOAD_STATUS:1>Y <MY_IOTA:6>EU-005 <MY_IOTA_ISLAND_ID:6>EU-005 <IOTA:6>AF-004 <IOTA_ISLAND_ID:6>AF-004 <APP_L4ONG_SATELLITE_QSO:1>N <APP_L4ONG_CONTEST:1>N <APP_L4ONG_QSO_CONFIRMATIONS:543>[{"CT":"QSL","S":"Requested","R":"Requested","SV":"Electronic","RV":"Electronic"},{"CT":"EQSL","S":"Requested","R":"Requested","SV":"Electronic","RV":"Electronic"},{"CT":"HAMQTH","S":"Requested","R":"No","SV":"Electronic","RV":"Electronic"},{"CT":"HRDLOG","S":"Requested","R":"No","SV":"Electronic","RV":"Electronic"},{"CT":"CLUBLOG","S":"Requested","R":"No","SV":"Electronic","RV":"Electronic"},{"CT":"QRZCOM","S":"Yes","R":"Yes","SV":"Electronic","RV":"Electronic"},{"CT":"LOTW","S":"Requested","R":"No","SV":"Electronic","RV":"Electronic"}] <APP_L4ONG_QSO_AWARD_REFERENCES:189>[{"AC":"DXCC","R":"29","G":"AF","SUB":[],"GRA":[]},{"AC":"WAC","R":"AF","SUB":[],"GRA":[]},{"AC":"WAZ","R":"33","SUB":[],"GRA":[]},{"AC":"IOTA","R":"AF-004","G":"AF-004","SUB":[],"GRA":[]}] <APP_L4ONG_MY_AWARD_REFERENCES:59>[{"AC":"IOTA","R":"EU-005","G":"EU-005","SUB":[],"GRA":[]}] <EOR>
Windows 10 Pro & LOG4OM - V2.29.0
Re: Import of WSJT .adi ~ EA8DR State of TF..??
I just did a test QSO using WSJT with EA8DR and the QSO was transferred to Log4OM with nothing in the state field even after a QRZ lookup so I dont have a clue where the state came from unless it was originated by HRD also?
The drop down only shows two possibilities eg Tenerife or Las Palmas but if you dont select either or save the edit the field will remain empty. We include these choices in case there is a WASP (Worked all Spanish Prefectures award) at some time in the future.
When we export an ADIF we export exactly the data in the logbook so if state field contains anything it gets exported
Remedial action
To remove the state go to the QSO Manager
Select the QSO
Select the 'Single field update' tab
Select the 'State' field
Check the box 'Clear field'
Click 'Update' button
That will resave the QSO with an empty state field.
Its not important
Even if some QSO's have a state when they should not your WAS award will be correct because the award first sorts according to DXCC entity, in this case 291 for the US so your award will be accurate even if some odd QSO for a Spanish contact had 'TX' (Texas) in the state field it would not be included.
Same applies to WAJA (Worked all Japanese Prefectures Award), WAIP (Worked all Italian Provinces Award) etc - The DXCC entity is the prime filter before collating the contents of the State/Prefecture field
G8LIY
Post by G8LIY »
G4POP wrote: 01 Mar 2021, 16:08 I just did a test QSO using WSJT with EA8DR and the QSO was transferred to Log4OM with nothing in the state field even after a QRZ lookup so I dont have a clue where the state came from unless it was originated by HRD also?
Remedial action
Select the QSO
Its not important
Thanks...
I have looked at some other EA8's... They are O.K
This one is only a few days old direct from WSJTX .adi file... I have not used HRD properly since 2015, a few QSO's entered 2018..??
I have spotted a few other STATE anomalies, an old UA9MA with "OM", State drop down contains lot's of Departments/Regions..??
Will try your fix ASAP
Many Thanks.. 73 Dave
See my comments and reflect if it's really an issue worth wasting time on?
G8LIY
Post by G8LIY »
G4POP wrote: 01 Mar 2021, 18:25 See my comments and reflect if it's really an issue worth wasting time on?
Hi Terry,,
It's done...
In the QSO Manager I dragged the State Field next to Callsign, sorted on State... I was able to fix 18 quite quickly...
I hate bad data... A cast off(habit) from my previous life :)
I have another Query, IOTA and Island Group... For another Post
Best 73 Dave
