[SOLVED] V 2.12.0 not put frecuency in log from CAT with HAMLIB
lu4hne
Post by lu4hne »
Download the latest version and now it allows you to see the 2 vfo but when registering a contact it does not copy the frequency in the log
frecuencia 2.11.png (18.19 KiB) Viewed 3796 times
In version 2.12 it correctly shows both vfo but it does not copy the value in the contact, even when saving it does not copy the value either.
disable
frecuencia 2.12.png (23.48 KiB) Viewed 3796 times
My Rig is FT-890
this option new "VFO mode" parameter no make change if enable or disable
Max LU4HNE, 73 DX.
Re: V 2.12.0 not put frecuency in log from CAT with HAMLIB
OM,
Have you tried the same routines while using OmniRig for CAT control?
That would provide additional trouble shooting details.
lu4hne
Post by lu4hne »
Thanks for answering, unfortunately with omnirig my yaesu ft-890 does not work, only with hamlib I have been able to use CAT
Max LU4HNE, 73 DX.
lu4hne wrote: 02 Apr 2021, 20:41 Thanks for answering, unfortunately with omnirig my yaesu ft-890 does not work, only with hamlib I have been able to use CAT
Max,
I seem to recall that other OMs have expressed similar and were able to get OmniRig working using a different FT 'ini' file, but don't recall which one. Doing some searches here on the forum might provide those prior threads.
FWIW - we're also currently testing a new Hamlib version that should address the frequency issue. Can't give you a date for that release, but may not be a very long wait.
lu4hne
Post by lu4hne »
Thanks Nolan for your answer, I will keep trying with an omnirig configuration while correcting hamlib, I prefer it
Max LU4HNE, 73 DX.
lu4hne
Re: [SOLVED] V 2.12.0 not put frecuency in log from CAT with HAMLIB
Post by lu4hne »
Solved in version 2.13.
Max LU4HNE, 73 DX.
