How to recover settings after failed shutdown?
ac5aa
Post by ac5aa »
Hello - we had a severe storm on Friday night and while I was shutting down Log4OM and the PC, power was lost. On restarting Log4OM today it performed as if this were the first login and asked for settings to be completed before going further. While I was able to connect successfully to the log file (thankfully) all the other setup options are gone. Is there a way to recover them? Which file contains them? Thanks in advance - I continue to enjoy Log4OM.
73, Duane AC5AA
73, Duane AC5AA
Re: How to recover settings after failed shutdown?
See the section in the user guide about restoring your set up.
ac5aa
Post by ac5aa »
Doh! I should have looked there - thanks, Terry.....
73, Duane AC5AA
ac5aa
Post by ac5aa »
For others, it is detailed in the "Emergencies" section starting on P 225. Hats off to Terry and the gang for the manual which covers LOTS of info you may need. The fix worked great for me.
73, Duane AC5AA
:D :D :D
