Award Allert
Moderator: OE6CLD
N5HC
Award Allert
Post by N5HC »
I created a rule that should match a selected award.
When I spot simulate with a call included in the reference awards it does not alert.
Some detail about the rule:
By stats = Ignore.
Call/Dxcc
DXCC = All
Callsign = I iterated thru using a specific callsign thru wildcard and no callsign at all.
BTW Just a plain rule without award works fine.
Any limitations or specific issues using awards as a rule criteria?
73 de N5HC
/Conny
Re: Award Allert
N5HC wrote: 04 Jul 2021, 14:38 I created a rule that should match a selected award.
By stats = Ignore.
Call/Dxcc
DXCC = All
Conny,
What version of Log4OM2 do you have installed? Current release is: v 2.15.0.0
Could you also provide screen clips of each of the tabs for the Alert you are assembling?
Be sure to also review the current User Guide dated: 02/07/2021 1:25 PM
Alert Configuration starts on Page 74 and your question might addressed by the graf below the top image on Page 76.
N5HC
Re: Award Allert
Post by N5HC »
Using release is: v 2.15.0.0
Have User Guide dated: 02/07/2021 1:25 PM, (and read/searched it)
Did read thru page 74 thru 76 and I do get simple rules to work based on DXCC/Call signs etc.
However those pages does not specifically address awards.
Attaching screen clips.
Screenshot 2021-07-04 090005.png (27 KiB) Viewed 4131 times
Screenshot 2021-07-04 085950.png (33.16 KiB) Viewed 4131 times
Screenshot 2021-07-04 085921.png (23.78 KiB) Viewed 4131 times
73 de N5HC
/Conny
N5HC
Re: Award Allert
Post by N5HC »
Screenshot 2021-07-04 090103.png (31.62 KiB) Viewed 4131 times
Screenshot 2021-07-04 090046.png (41.28 KiB) Viewed 4131 times
Screenshot 2021-07-04 090022.png (28.91 KiB) Viewed 4131 times
73 de N5HC
/Conny
N5HC
Re: Award Allert
Post by N5HC »
Screenshot 2021-07-04 090217.png (50.45 KiB) Viewed 4131 times
Screenshot 2021-07-04 090203.png (65.57 KiB) Viewed 4131 times
Screenshot 2021-07-04 090146.png (79.4 KiB) Viewed 4131 times
73 de N5HC
/Conny
N5HC
Re: Award Allert
Post by N5HC »
Screenshot 2021-07-04 090326.png (69.1 KiB) Viewed 4131 times
Screenshot 2021-07-04 090249.png (78.42 KiB) Viewed 4131 times
73 de N5HC
/Conny
Re: Award Allert
Conny,
Love 13 Colonies & Route 66. Been participating in both since 2012 and all via CW. Have managed sweeps on both since 2013.
As for an Alert via an 'award' you have generated I'm thinking that Claus or Terry will also chime in on that setup.
As for my 13 Colonies this year I just set up individual callsigns (IE: K2A, K2B, WM3PEN, GB13COL, etc..) and turned them off as I worked each one. My mode/emission was set for CW so for me that was easy.
I'll look into your approach next time around or in time for Route 66 as the approach is the same.
