Shutting down hangup
DJ9UN
Post by DJ9UN »
Hi, when i am clossing the program it hangs up and not closing, i have to go to the Task manager to close the program. Perhaps i made wrong settings.
I am using an FTDX3000 with Omnirig version 2.16.00 and Windows 10
Thank you for comments or advice
LOG4OM Shutting down.JPG (16.88 KiB) Viewed 2326 times
Re: Shutting down hangup
Have you tried un-setting automatic upload to LOTW on closing?
DJ9UN
Post by DJ9UN »
Hello, than kyou, yes i unswiched the automatic upload from LOTW and now all is fine.
Thank you
Alain
DJ9UN wrote: 12 Aug 2021, 08:44 Hello, than kyou, yes i unswiched the automatic upload from LOTW and now all is fine.
Thank you
Alain
OK Alain,
We think its a recently added switch to the LOTW auto upload but cant check until Lele comes back from holiday in a couple of weeks
DJ9UN
Post by DJ9UN »
Thank you for the help, no problem and enjoying radio. Perhaps the award WAE will also be included in the next uptates. I am sure its on your list. HI HI 73 Alain :D
WA2SQQ
Post by WA2SQQ »
I’ve also experienced this problem several times. I usually wait about two minutes, right click, and close the window. It’s very unpredictable, but not a major concern.
