Gridtracker Uploading QSO'S?
PA7RA
Post by PA7RA »
Good morning,
I have been working with LOG4OM for some time now.
When I make a qso it is sent to QRZ.COM,hrdlog.net,eqsl and clublog.
Only when I do FT8 or FT4 then I work with WSJT-X and Griddtracker then the created qso is logged in LOG4OM but not sent to the external logs such as E-qsl and QRZ.COM.
What have I not set up correctly and who has the solution for this or is this supposed to be the case?
thanks in advance HPNY
Rien, PA7RA
Re: Gridtracker Uploading QSO'S?
PA7RA wrote: 29 Dec 2021, 09:33 Good morning,
Rien, PA7RA
So how are the QSO'S being retrieved from the JT and Gridtracker programs?
PA7RA
Post by PA7RA »
Hello Terry,
the qso's are to LOG4OM via Gridtracker see screenshot.
Tnx Rien, PA7RA
I cannot see the screenshot well enough to understand it however try NOT sending from Gridtracker but use the UDP method described in our user guide to get the QSO's direct from WSJT
PA7RA
Post by PA7RA »
Terry,
t is possible to log the qso's in LOG4OM made in WSJT-X
Only these are not automatically sent to QRZ.COM and E-qsl Ectr.
I have to do that manually so the link between WSJT-X and LOG4OM is good I think.
Only if a qso is made outside of LOG4OM it is not sent and not set to Y of Yes sent in the columns that are before it in log4om.
I hope my story is a bit clear for you sorry for the bad english.
And where Y of Yes is now in the column is because I sent it manually as you can see the one from CLublog is still on N.
AND yet the clublog is also set up correctly because sending manually is possible!
Greeting
Rien, PA7RA
If you set up as described in our user guide using UDP the QSO's will be uploaded to the on line logs as they are worked
