Unknown failing connection attempts in log
DK9SAS
Post by DK9SAS »
Just a little annoyance for me, but surely something isn't working as expected.
My log reports failed connections attempts, while having clusters and chat disabled:
Code: Select all
21:32:19.463 Info:          [#=zqLfBOIQ=] : Starting TALK client
21:32:22.096 Error:         [TalkServer][#=zV_hBrNtCVv2PYn3Lcg==] : [EXCEPTION] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte
21:32:24.482 Info:          [#=zqLfBOIQ=] : Starting TALK client
21:32:27.115 Error:         [TalkServer][#=zV_hBrNtCVv2PYn3Lcg==] : [EXCEPTION] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte
21:32:44.509 Info:          [#=zqLfBOIQ=] : Starting TALK client
21:32:47.135 Error:         [TalkServer][#=zV_hBrNtCVv2PYn3Lcg==] : [EXCEPTION] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte
21:32:52.112 Info:          [#=zqLfBOIQ=] : Starting TALK client
21:32:54.741 Error:         [TalkServer][#=zV_hBrNtCVv2PYn3Lcg==] : [EXCEPTION] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte
21:32:57.134 Info:          [#=zqLfBOIQ=] : Starting TALK client
21:32:59.773 Error:         [TalkServer][#=zV_hBrNtCVv2PYn3Lcg==] : [EXCEPTION] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte
Programm tries to open a TCP connection to 209.59.197.104.bc.googleusercontent.com, ports 18260++ (likely a Google cloud service)
Sadly the log won't tell me what connection fails exactly even with trace logging, I suspect some scheduled updating fails..
Happy New Year :)
73 Sascha
Re: Unknown failing connection attempts in log
Sasha,
You need to review the thread I have pasted below. Danielle has provided a programming change that will correct your issue.
Read through the entire thread and make the change noted and you will be fine.
https://forum.log4om.com/viewtopic.php?f=32&t=7198
