I can't setup the upload to HamQTH, it doesn't upload.
I fill in my callsign and password.
But i get by uploading the following message:
[HAMQTH] Upload failed: Forbidden Forbidden for qso Callsign: YO5PIP Date: 3-1-2022 20:20:15 Band: 40m Mode: FT8
HAMQTH END
What is going wrong?
How to use logging to HamQTH
TX: Flexradio 6400 / Flex Tuner Genius XL / Icom IC9700 / Mic. Heil PR781 / Antenne Hexbeam by SP6CYN / Homemade G5RV / Kelemen 40 Meter Dipole
Re: How to use logging to HamQTH
Have you checked the HamQTH website.? If settled up in Log4OM the upload to HamQTH is automattet. If you try later to upload the same contact via manual upload you will get an Error.
Hi Juergen,
I tried to upload a adif file on the HamQTH website and then i don't get an error.
But when i upload manualy by the qsl manager in Log4om then i get the error and not uploading qso's
I tried with qso's that i had make after uploading the adif on the website.
Hello OM (no name in your signatuere),
how you have settet up your uploads in the Log4OM setup ? If you have settet it up to automatic
uploads and you use JTalert the contacts will be uploades around a minute after the contact was
logged.
That means that Log4OM does manage the upload after receiving an ADIF message via UDP.
If you have checked the "Automatc Upload" in Log4OM and you try later to upload an ADIF
So first of all, go to the HamQTH account and check your log there. If the contacts are
stored all is fine if not ask again.
logged.
