Single label printer
k7zv
Post by k7zv »
As a new user this is my 1st post. I am using Log4OMV2 ver. 2.18.0.0 and I have been struggling to match up my DYMO Labelwriter 450 Turbo to print single QSL labels. I have search throughout this forum for someone successfully implementing this printer. My previous logging program was DX4WIN and I have used this printer for all my QSLing needs. Being I already have this printer I would like to use it. So if there is any user on this forum using this printer I would appreciate some feedback.
Otherwise I am open to replacing the printer with another brand single address label printer that users are presently using for this purpose that works with Log4omv2.
Rich K7ZV
Grants Pass Oregon
9k2hn
Re: Single label printer
Post by 9k2hn »
Today it took me a few seconds to print labels using Dymo 450, I'm using address label 30252 just set the sheet width to 8.9 & sheet height to 2.8, and (for sure row 1 & columns 1)
and you will be all set
9k2hn wrote: 16 Apr 2022, 09:52 Today it took me a few seconds to print labels using Dymo 450, I'm using address label 30252 just set the sheet width to 8.9 & sheet height to 2.8, and (for sure row 1 & columns 1)
Then save it for future use or better still send it to us so that we can add it to the default label templates
k7zv
Post by k7zv »
Thanks 9K2HN for your input. A few days ago I found a post by AC5EZ for setting up a Seiko SLP-750 that helped me understand the steps needed. So between you both I successfully have my Dymo 450 Turbo printing labels.
G4POP I would be happy to send it to you so you can add it to the default label templates but to be honest I do not know how to find in and send to you. So if you can instruct me to exactly how find and where to send it I will be happy to do so. If you want to private email this it will be OK.
Thanks,
Rich K7ZV
pc2ky
Post by pc2ky »
k7zv wrote: 17 Apr 2022, 10:43 Thanks 9K2HN for your input. A few days ago I found a post by AC5EZ for setting up a Seiko SLP-750 that helped me understand the steps needed. So between you both I successfully have my Dymo 450 Turbo printing labels.
Thanks,
Rich K7ZV
Can you telle me how to put the Dymo into the programm? I runn Log4om 2 v2.22.00 I have also a Dymo labelwriter 450.
With kind regards: Henry PC2KY
9k2hn
Post by 9k2hn »
This is a screenshot of my setting
Screenshot 2022-05-30 064314.png (27.55 KiB) Viewed 2320 times
pc2ky
Post by pc2ky »
9k2hn wrote: 30 May 2022, 03:43 This is a screenshot of my setting
Hello 9K2HN for your replay.
How did you fill in "user_Custom-Dymo"?
I can not find anny dymo printer in the label definition.
For the Dymo i have the programm from the Dymo website.
With kind regards: Henry Bolster PC2KY
Type your chosen name into the field labelled 'NAME' and click the save icon to the right (Floppy disk)
