Not save new QSO
iw2nfn
Not save new QSO
Post by iw2nfn »
I have some problem to save a new QSO
As a image that I attached ...I fill all information in the QSO box...but when I click the + button on the right of the monitor...all information in the box are deleted but the QSO will not save...
What is the problem?
Thank in advance
73 de IW2NFN
New QSO-1.jpg (198.5 KiB) Viewed 2837 times
Re: Not save new QSO
Check the log file it will recorded what happens
I´m shure that the QSO is saved if you hit the + and you don´t get any error message in a popup window.
Below the QSO list on the left you see the little refresh button. Hit it and the QSO list will be refreshed.
iw2nfn
Post by iw2nfn »
Thanks for all answare....
NEVER POST YOUR LOGFILE TO THE FORUM IT CONTAINS SENSITIVE INFORMATION
Here I attached the log file...
Yes I already hit the button on the bottom but... I never don't see my new qso
Regards
I told you never to post your log file - I have deleted it de G4POP
iw2nfn wrote: 18 Apr 2022, 10:54 Thanks for all answare....
Regards
SEE MY NOTE ABOVE
Your logfile says that your database is read only probably because you have saved it to the 'Program files' folder of similar
iu1opq
Post by iu1opq »
I would like to know if and how you solved the problem because the same thing is happening to me too.
I checked the archive where I save my logs and it is open for writing but I can't solve the problem
I saved a log normally but the next one was no longer saved, luckily I checked in Recent QSO's otherwise I wouldn't have even noticed.
Has anyone with the same problem solved it?
iu1opq
Post by iu1opq »
after having clicked on the link to Clublog on the CY9C site that I had just connected to, I unfortunately introduced a virus into my PC which is blocking all the folders on the system, changing them to read-only even though I correct them. obviously for this reason Log4OM cannot reach the database folder. so the problem must be looked for elsewhere and not on Log4OM. warning only to spread the information
Immagine WhatsApp 2024-08-26 ore 22.45.51_825b73cc.jpg (214.04 KiB) Viewed 1658 times
iw2nfn
Post by iw2nfn »
iu1opq wrote: 27 Aug 2024, 09:20 I would like to know if and how you solved the problem because the same thing is happening to me too.
I moved my database in writable folder.
iw2nfn
