Alert RTTY mode
F6FLU
Alert RTTY mode
Post by F6FLU »
I would like to get an alert only if mode = RTTY whatever the call
I did that but apparently it didn't work...
Thank you for your advice
2022-11-02 16_05_55-Cluster #1.jpg (110.67 KiB) Viewed 544 times
Dan - F6FLU
https://F6FLU.org
Re: Alert RTTY mode
Unfortunately the CLUSTER protocol doesn't provide any information about the MODE used by the operator.
In some cases Log4OM is able to detect the mode from the NOTES added to the SPOT by the reporter (or based on specific frequencies on bandplan)
The "MODE FILTER" works on those (few) well identified spots (works better on SUPERCLUSTER data that are providing MODE too)
I've identified a small glitch on the alert routine that may create some false positive reports and will be fixed in the next beta.
For generic use, please note that MODE filtering is very selective as very few spots can be identified exactly on a specific MODE.
Thanks for reporting
F6FLU
Re: Alert RTTY mode
Post by F6FLU »
OK Daniele Thanks ...
Dan - F6FLU
https://F6FLU.org
