Missing confirmations after import
k4em
Post by k4em »
I set up a new computer, installed Log4OM 2.28 and manually reconfig settings. I exported ALL log info on old computer and imported into new computer with Quality checks at #3. You can see the missing confirmations in the attached pics. The missing confirmations are also on MANY other entities not just CE0Y. Under Maintenance I ran 'Rescan QSO Reference's' and monitored via Help/Realtime log, until finished. Rebooted and same issue.
Any help would appreciated.
Dave
k4em
ce0y new computer.png (7.97 KiB) Viewed 892 times
ce0y old computer.png (7.29 KiB) Viewed 892 times
Re: Missing confirmations after import
1. Is the view filter set to worked or just confired?
2. Have you done a complete download from LOTW?
3. On import what did you nhave the 'Award check' set to?
k4em
Post by k4em »
On the new computer Log4OM I made one change. Under Settings/Confirmation; I added 'Thanks & 73' in the 'QSL default message', the pic shows it after I removed it. I deleted that message and it is now working, as you can see the CE0Y now shows all my confirmations. I also checked 10 to 15 other PFX's and all is now good.
Dave
k4em
conf computer.png (7.88 KiB) Viewed 885 times
conf new computer.png (13.47 KiB) Viewed 885 times
k4em
Post by k4em »
To test, I just went back into settings/confirmations, and added the Thanks & 73. It did not change anything, all pfx show up fine. Weird.
Dave
k4em
