Automatischer QSO- Upload zu eQSL ab Version 2.27.1.0
Moderator: DF5WW
DM2DK
Post by DM2DK »
Hallo zusammen, zu meiner Ausgangssituation:
Ich arbeite seit Jahren mit WSJTX und JT Alert, das Loggen erfolgt mit LOG4OM, der Upload der QSO's zu eQSL erfolgt dann automatisch aus LOG4OM.
Seit dem Update 2.27.1.0 funktioniert der automatische Upload aber nicht mehr, sondern nur noch manuell. Auch die Version 2.28.0.0 brachte keine Änderung.
In den Einstellungen wurde nichts geändert, Paßwort und Nutzername für eQSL stimmen.
Nach einem Downgrade zur Version 2.26.0.0 funktioniert er QSO- Upload jedoch wieder wie gewohnt.
Gibt es dafür eine Erklärung und Lösung?
Vielen Dank im Voraus.
Re: Automatischer QSO- Upload zu eQSL ab Version 2.27.1.0
DM2DK wrote: 23 Jun 2023, 18:18 Hallo zusammen, zu meiner Ausgangssituation:
Hello everyone, about my initial situation:
I have been working with WSJTX and JT Alert for years, logging is done with LOG4OM, the upload of the QSO's to eQSL is then done automatically from LOG4OM.
Since update 2.27.1.0, however, the automatic upload no longer works, only manually. Version 2.28.0.0 did not bring any changes either.
Nothing has been changed in the settings, the password and username for eQSL are correct.
However, after downgrading to version 2.26.0.0, the QSO upload works again as usual.
Is there an explanation and solution for this?
Thanks in advance.
Detlef,
Major changes were made with respect to UDP Inbound connections. This has been discussed time and time and time again on the Forum. The information was also presented in the Release Notes with V 2.27.0.0.
The setting up and configuration of the UDP Inbound connections has been made far simpler. But y'all have to remember to read the Release Notes and even take some time to scan the "most current" User Guide if you have more questions.
Here is a link (from Release Notes) that talks about the basics an OM has to do when it comes to the UDP Inbound connections. https://forum.log4om.com/viewtopic.php?t=8260
Bottom line is that you have to REMOVE what you have in place and then use the Inbound Connection routine and select the Preset Config options. You can still adjust items selected in those presets if you have the need to do so.
Be sure to first note what UDP ports you are currently using to link WSJTx, JTDX, Gridtracker and/or JTAlert.
Then DELETE those existing UDP connections and then build new ones.
The "current" User Guide is dated: 17/06/2023 11:39 AM
The Integration with the JT programs starts on Page 216 of that U.G.
Rolling back to V 2.27.0.0 will not resolve the issue. Nor will any Windows O/S updates help. You have to follow the directions and my very quick summary noted above.
Here is a link to the Log4OM website/resources page. https://www.log4om.com/resources/ Click on the tab labeled: "Working With JT Applications" and download that PDF. Lele created that document as a bit of an explanation of the JT applications UDP connections.
DM2DK
Post by DM2DK »
Hallo Nolan,
vielen Dank für die schnelle Antwort auf meine Fragestellung und die wertvollen Hinweise zur Lösung.
Die Diskussion zu diesem Thema habe ich leider nicht verfolgt. Ein Fehler.
Ich werde das nun nachholen und mich mit dem Handbuch beschäftigen.
Nochmals Danke für die Unterstützung. Super.
73 de Detlef
DM2DK
DM2DK
Post by DM2DK »
Hallo zusammen,
das automatische Hochladen der QSO's zu eQSL funktioniert nun wieder mit der Version 28.0.0 wie gewohnt.
Doch es gibt noch ein Problem, die Rufzeichen werden im Hauptfenster nicht übernommen, das Feld bleibt leer.
Ich kann dafür im aktuellen Handbuch einfach keinen Lösungsweg finden.
Kann jemand helfen?
73 de DM2DK
