LOG4OM Shut Down Problem
WA2SQQ
Post by WA2SQQ »
Currently using version 2.28 under Windows 10. When I shut down and it goes into the backup mode, it will display the message and keeps displaying it until I manually close the window. It is backing up the files, just never terminates the message. This has been occurring with the last 4 versions. This happens about 75% of the time. Any idea how to fix this?
Re: LOG4OM Shut Down Problem
What location are you saving the backups?
Are you sure its the backups causing the delay not upload to on line logs?
Have you checked the Log4OM logfile to see what error messages there may be?
WA2SQQ
Post by WA2SQQ »
I save my log file to two locations - a separate hard drive in the same PC and to a USB thumb drive.
I've tried only saving to one location, either or, but it makes no difference.
I have not looked for an error since its not displaying an error message - it just hangs up once the backups are completed (successfully). It's also not happening all the time. It's not a huge issue since its easy to close the window - just thought I'd mention it in case others have experienced it.
WA2SQQ
Post by WA2SQQ »
Here is the backup section of the log file
[SplashScreen] : Asynchronous activities completed
2023-07-21 01:55:05.6142 INFO: [SplashScreen] : Starting backup...
2023-07-21 01:55:05.6202 INFO: [BackupManagement] : Starting backup process
2023-07-21 01:55:07.3654 INFO: [BackupManagement] : Backup folder is set to F:\WA2SQQ LOG4OM BACKUP\V2\
2023-07-21 01:55:07.3659 INFO: [BackupManagement] : Backup monthly folder is set to F:\WA2SQQ LOG4OM BACKUP\V2\Historic\
2023-07-21 01:55:08.5194 INFO: [AdifManagement] : Begin export to ADIF file: F:\WA2SQQ LOG4OM BACKUP\V2\WA2SQQ_20230721_015507_backup.adi
2023-07-21 02:03:45.1683 INFO: * [AdifManagement][516649 ms] : Export to ADIF file completed: 9630 QSO
2023-07-21 02:03:45.1713 INFO: [BackupManagement] : Backup created: F:\WA2SQQ LOG4OM BACKUP\V2\WA2SQQ_20230721_015507_backup.adi with file size of 21080522 bytes
2023-07-21 02:03:50.8633 INFO: [BackupManagement] : Backup copied to : F:\WA2SQQ LOG4OM BACKUP\V2\Historic\WA2SQQ_Jul23_backup.adi with file size of 21080522 bytes
2023-07-21 02:03:56.7554 INFO: [BackupManagement] : Backup copied to : F:\WA2SQQ LOG4OM BACKUP\V2\Historic\WA2SQQ_Jul23_config.json with file size of 42948 bytes
2023-07-21 02:03:56.8008 INFO: [BackupManagement] : Backup copied to : G:\LOG4OM BACKUP\WA2SQQ_20230721_015507_config.json with file size of 42948 bytes
2023-07-21 02:03:56.8018 INFO: * [BackupManagement][531181 ms] : Backup process terminated
2023-07-21 02:03:56.8023 INFO: [Initialization] : ##### Closing running user profile #####
Bob,
As a trouble-shooting item how about your turn off the 'auto-upload' item for LOTW?
See if that makes any difference.
Bob,
Change the backup location to a cloud location, either Google Drive or Dropbox
WA2SQQ
Post by WA2SQQ »
Auto upload was turned off - ill try a cloud location. Sri for the delay in responding but I've been very busy.
HS0ZQG
Post by HS0ZQG »
Iam having the same issue which seemed to just happen , it was working perfectly fine , when I exit the program It would upload all the contacts into Lotw
Now what happens it just seem to hang and the only way is to force close LOG4ON v2
The message is similar to the above
Uploading LOTW data ( 120 seconds timeout)
Saving form status...
Shutting down Log4OM application
" then Hangs there without anything happening "\
Yes I did untick automatic upload on application close , and yes it did close out the program , however no upload as expected !
I can also do a save export manually to LOTW using TQSL
What possibly could be the issue... it seems to be the database of sorts ...
Russell E21AZ ...HS0ZQG
Russell,
Rather than exporting an ADIF to TQSL ... why not utilize the the QSL Manager located at: Utilities / QSL Manager.
Then select LOTW. A couple key clicks and all your Q's will be uploaded straight-a-way.
Saves a number of steps vs. creating an ADIF and then working with TQSL. The QSL Manager does all that for you.
Now as for the "auto upload" when Log4OM closes. Than can be a whole different issue and I'll let other team members address such.
Personally I prefer to upload all my Q's via the QSL Manager. Not a fan of the "auto upload" option(s), but that is just the way I work my station.
