Stats on a call
F4BPO
Stats on a call
Post by F4BPO »
Hi Terry and all,
I am struggling to get the stats on a call when I work a Dxpedition.
For example if I am chasing 4W8X, when I put their call in the callsign field of Log4OM, I am supposed to see on the F1 tab the light blue color for the call, but I only see orange or green. This means I worked or confirmed Timor Leste but how to see if I worked 4W8X ???
It is a bit painfull as I always have to go to worked before (F10) tab and check all my contacts with them to see if I worked them.
Not sure if I am missing something here ?!?
73 de F4BPO Greg
Re: Stats on a call
Greg,
Your missing the light and dark blue colours which mean ...
Light blue - Actual call sign entered was worked before but not confirmed on the band/mode indicated
Dark Blue - Actual call sign entered was worked before and is confirmed on the band/mode indicated
Orange - I have the country confirmed on 17m phoneon the band/mode indicated, but not by the call entered
Green - I worked the country on that band/mode but its not been confirmed.
Grey - Country not worked on the band/mode indicated
See my example below, I worked the call sign entered on 60m but it is not confirmed - whereas I worked the same station on 40m and it is confirmed - Page 35 of user guide 'Statistics (F1) matrix'
Screenshot 2023-11-23 083931.png (4.16 KiB) Viewed 6672 times
F4BPO
Re: Stats on a call
Post by F4BPO »
I never ever see light and dark blue.
Is there a setting for this ?
So how to see easily if I put 4W8X in the callsign field where I did contact them and where I did not contact them already ?!?
73 de F4BPO Greg
Re: Stats on a call
What Logh4OM version are you using? you can see its working fine here!
Light blue square indicates worked by band and mode so if there is no light blue or dark blue your have not worked him anywhere
No setting controls this its set to work automatically
F4BPO
Re: Stats on a call
Post by F4BPO »
I have v2.30.1.0 but I have never seen blue for long time.
For example:
No blue here it is the same for all stations I worked I never see anything related to the call itself but rather the country.
As you can see the stats are for Timor Leste where I have confirmed already on 40, 20 and 10M Digi while the other orange are for most of them 4W8X but they are not in blue.
73 de F4BPO Greg
Re: Stats on a call
What have you got set here?
F4BPO
Re: Stats on a call
Post by F4BPO »
I have LOTW / QSL / QRZ
73 de F4BPO Greg
Re: Stats on a call
Change to worked only and see if you get blue squares
Seems that you dont have that station confirmed by any method and your set to just see confirmed QSO data in statistics
F4BPO
Re: Stats on a call
Post by F4BPO »
same
73 de F4BPO Greg
F4BPO
Re: Stats on a call
Post by F4BPO »
When I compare you screenshot with mine I see that below Country - Call / 10m - Call / Phone - Call it is red but it is missing the small square on the right which represent the callsign.
Where could this come from ?!
We clearly see the square on your screenshot not mine
73 de F4BPO Greg
