Statistics Grid data from manual callsign entry
The Statistics chart fills when a call is selected from the received cluster spots. Often times I need it to fill when I manually enter a call to check what my stats are and whether I "need" that band/mode. This would be very helpful to me and I don't know why it doesn't already function that way. Thanks!
73, Duane AC5AA
Re: Statistics Grid data from manual callsign entry
Duane,ac5aa wrote: 07 Dec 2023, 15:11 The Statistics chart fills when a call is selected from the received cluster spots. Often times I need it to fill when I manually enter a call to check what my stats are and whether I "need" that band/mode. This would be very helpful to me and I don't know why it doesn't already function that way. Thanks!
What version of Log4OM are you using?
My stats are working FB when I manually enter a callsign into the Main UI.
Do you have Realtime Callsign Stats 'enabled' in your Configuration / Performances?
- ki5io_performances.png (44.96 KiB) Viewed 11288 times
Hi Nolan,
Thanks for the response - I'm running 2.29.0.0. I didn't download the latest yet because the fix it contains isn't pertinent to me. Yes, I have the item enabled that you indicate. So, you're saying if you manually enter a callsign into the call field, the grid to the right of the spots window ("Statistics/Filters/Beam/View") populates with your band/mode info for that entity? It does not for me unless I click on a spot in the cluster window. Then all the data is populated. This makes is useless for ignoring spots and doing my own RXing to try to nab one before it gets spotted.
Here, I have entered your call - no grid: Here, I have clicked on a spot, and the grid appears to the right of the spots window:
[attachment=0]2023-12-07 (1).png[/attachment
Just in case we're not talking about the same "Statistics" grid.
- 2023-12-07 (1).png (154.47 KiB) Viewed 11263 times
73, Duane AC5AA
Only the two grids shown in the first screen shot are activated by manual entry
The grid in the cluster window as shown below only is actioned by clicking a cluster spot - Not by manual entry
OK, thanks, Terry - I'd prefer it in the larger view, but I see I can find the same info (after decoding colors) in the upper stats window. Somehow that just never registered with me.
73, Duane AC5AA
