LOg4OM populate callsign in Entrywindow from JTDX?
lb3re
Post by lb3re »
Hi
is there a way to syncronise the populate callsign from JTDX into entry window of LOG4OM when clicking a call in JTDX?
In my 1th computer its ok and show if I worked the DXCC b4 etc. , but in 2nd computer its not populating. I cant see any difference. :D
I dont know where i selected it at all..
73s LB3RE
Re: LOg4OM populate callsign in Entrywindow from JTDX?
Your connection's for UDP are not set up correctly, see our user guide for details
lb3re
Post by lb3re »
Hi
but the QSO are coming correctly.
Only when clicking the callsign ?
73s LB3RE
lb3re wrote: 29 Jan 2024, 22:25 Hi
73s LB3RE
seperate actions, you can have one work and the other not so study user guide please
lb3re
Post by lb3re »
I have now compared TWO computer settings in LOG4OM and JTDX.
They are identical and have the same UDP ports from JTDX
UDP broadcast in JTDX 2236 adn 2237
LOG4OM
2236 JT message
2237 ADIF message
same aren't working in PC 2.
Only work in PC 1
lb3re wrote: 29 Jan 2024, 23:10 Hello
LOG4OM
2236 JT message
2237 ADIF message
Only work in PC 1
And is emote configured in JTDX as page 223 re 2nd port of our user guide
lb3re
Post by lb3re »
i tried this also with 2241 as JT message in JTDX, but still no appearing in "remote control" gives callsign in entry windows with 2241 in LOG4OM ... :D
so strange it will not work...
73s LB3RE
Something using that port perhaps?
lb3re
Post by lb3re »
No, i tried to restart my computer and have only JTDX and LOG4OM active.
I dont see why this would not work.. I tested in TWO other computers and it works
Try changing port numbers in both programs
