Qrz.com
Qrz.com
Hello Terry,Richard here,I have subscribed to xml data on qrz.com and done the API settings on Log4om setup page,but not much is happening on screen,not sure what Force Station Callsign box means,I'd like to be able to see the other statios Qrz page on the top right panel of Log4om,thanks de Richard
Re: Qrz.com
Have you tested the QRZ connection in config/info providers, does it show a green check mark?
The API code is only used for upload to QRZ
Re: Qrz.com
Hello Terry,I'm not sure how to do that,where do I check that,is it on Qrz.com page or on Log4om
Re: Qrz.com
I did say in Config/Info providers and of course I refer to Log4OM, however here is a graphic
If you dont get a GREEN check (Tick) then either your QRZ user name or password are incorrect
Password - NOT API code
Re: Qrz.com
Ok Terry I got it working,looks very good,very well written program,thanks again
