Hello all
I went to see how many POTA I have. I noticed not all was listed under [view] [award status] there was ten or so I knew I had more. I went to the manual and found on page 173 to 174 it talked about POTA. I interpreted it as possibly needing to update as in Step 1. Well now there are no POTA listed under Award Status it is completely blank. I didn't check Step 8 that is the only thing I didn't do as I thought I haven't updated before. I geeked on that as I was merging an update to an existing data. I like to get this straighten out as I love POTA contacts and plan to activate parks in my area.
Thanks Again everyone for the help ahead of time.
POTA completley blank
Re: POTA completley blank
Allow time for each of the actions below to complete
First go to setting\update resources\Log4OM awards
Then in View\Award status select the POTA award
No while still in the award status dialog select the 'Maintenance' tab
Finally in the Maintenence tab select 'Rescan award references'
See also viewtopic.php?t=9041
Thanks Terry
I did what you listed. I now have all POTA Award Status Award View under All when checked lists all the POTA but is still doesn't show under Wkd my worked parks. What populates this when checked? I'm thinking a field on my log doesn't have the right info, but it should fill it in automatic. The Not wkd list all POTA but the Wkd and Wkd not cfmd are stillcompletely blank with no listing of even the parks.
I still trying to digest the link you provided. LOL Is that why it's not populating POTA Wkd and Wkd not cfmd?
Thanks again for the help.
- Screenshot (30).png (25.54 KiB) Viewed 3176 times
- Screenshot (29).png (45.36 KiB) Viewed 3176 times
No that has nothing to do with your issue but it will cause problems very soonKS4VOL wrote: 30 Mar 2024, 15:24 I still trying to digest the link you provided. LOL Is that why it's not populating POTA Wkd and Wkd not cfmd?
I assume that you 'Rebuilt the references' in the maintenence tab as instructed so cant understand why it works for all of use but not for you! Please email me an ADIF file of your logbook or the sqlite file if its not to large to email
Yes I tried again just to make sure and waited for all the red windows to complete. I waited for the red bars to complete when I was on the rescan award references Under Maintenance Tab and my cursor was at an hour glass and waited for it to change back. So I know they finished loading. I have two data SQLite database files only tried the Harriman Main. But looked on the other and it isn't filled in either. Do I need to do all SQLite files? I didn't think of it till just now. I'm thinking the one I did should have worked at least for that database. I emailed you the smaller one it is for the new QTH I live at now.
Just to let you know when I go to "First go to setting\update resources\Log4OM awards" as you asked it appears as if nothing happens. Maybe its just fast or changes in the background unseen on monitor.
Boy when I screw something up I do it good. LOL
Thanks for your help.
Remember there are approaching three quarters of a million POTA references so far so an award update or refresh of show all references can take a long time - patience is a necessity
With ADD/HD
I sent you a SQLite file in the second email. I waited until the refreshing data red file bar in lower right of Awards status/Award view was gone and gave it at least 20 minutes on my Pentium I9 with 64gigs of memory and a 2TB SSD. So if it takes longer then that on my computer others are really in trouble with much slower.
See your email and thanks again Sir.
is really a virtue.patience is a virtue
I apologize from the side.KS4VOL wrote: 02 Apr 2024, 13:40 With ADD/HDis really a virtue.patience is a virtue![]()
I sent you a SQLite file in the second email. I waited until the refreshing data red file bar in lower right of Awards status/Award view was gone and gave it at least 20 minutes on my Pentium I9 with 64gigs of memory and a 2TB SSD. So if it takes longer then that on my computer others are really in trouble with much slower.![]()
I can't imagine it taking that long. I'm wondering what kind of problem there is, but this screen will appear after a short wait.
Do you think it is correct to display the following in the current award database?
This screenshot shows the old code of the current database and the result of inputting Sig and Sig info for each QSO. POTA users will enjoy it.
I hope the database will be able to support the new code soon.
73, Kiyo JA9HWD
