I worked a DXpedition in Fox/Hound mode. When I logged the QSO, 'F/H Mode' automatically appeared in the comment field. The 'F/H Mode' was not shown in the JTAlert comment field within the JTAlert logging screen Popup. It appears Log4om inserted this comment. Now, every time I log an FT8 qso the 'F/H Mode' appears in the comment field.
Is there a way to turn off automatic comments? I do not need to have F/H Mode , POTA or an IOTA show up at all in my comment field.
Dave
k4em
Comment field populates with old data
Re: Comment field populates with old data
here is an example of adding 'F/H mode' to my FT8 qso's.
Dave
k4em
Dave
k4em
- log4om comments.png (54.05 KiB) Viewed 2244 times
Looks like your ft8 software is ending that data to log4om, we don't add it
Regarding "comment", Log4OM2 should not be processing anything.
You are probably entering comments in the WSJT-X log dialog. This will continue unless you delete it. Or it's in the continuous display settings related to JTAlert's comment display process.
If it is displayed on the QSL card, it depends on the JTAlert settings. This is different from the "QSLMSG" tag that is usually written on QSL cards.
JTAlert is processing to avoid a bug where comments are not set correctly in the WSJT-X "QSLMSG" tag, so please be careful when setting.
I think it's probably written in the JTAlert help.
73, Kiyo JA9HWD
Terry,
Thanks for the reply. I looked at WSJT-X Improved, the version I'm running. And tried an experiment and it worked.
When the Logging window was displayed, I typed TEST into the comment field and checked RETAIN. I then pressed OK to log the QSO. The word TEST now showed up in the comment field in Log4om. On the next QSO logging screen, I un-checked retain and deleted the word TEST, I pressed OK to log the QSO. Now the comment field is Blank as it should be.
I guess some buffer was not being cleared.
Thanks,
Dave
k4em
Thanks,
Dave
k4em
JUst happened to read this. Had to do the same thing. Initially the logging prompt screen did not have anything showing to add to the comment field, and retain was not checked. Had to populate the comment field, check "retain", log a contact, then log another contact, take the comment in the logging prompt screen out, uncheck "retain".
Thanks for the post, and solution, Dave. Right on target.
73 de Tor - K4TOR
Pee Dee of SC
Pee Dee of SC
