3D2 Conway Reef
G3ZSS
3D2 Conway Reef
Post by G3ZSS »
When trying to work the recent 3D2CCC operation from Conway Reef I noted an issue with the main QSO window not showing any contacts before with 3D2/c. The following picture shows my 2 contacts with the operation this week.
3D2 F1 Stats.png (44.37 KiB) Viewed 3548 times
However if I open the Award Status window you can see that I have already worked 3D2/c on numerous bands
3D2 Award status.png (9.2 KiB) Viewed 3548 times
This has only ever happened to me with 3D2/c. All other QSOs with other DXCC entities are showing correctly in the F1 Stats window. I'm using v2.32.1.0
73 Peter G3ZSS
Re: 3D2 Conway Reef
Hi Peter,
I cant replicate the problem here using a manual entry of 3D2CCC on the same bands and mode, see screenshots below
Have you tried a manual entry instead of the UDP update from WSJT?
Conway two.png (3.19 KiB) Viewed 3515 times
Conway one.png (11.6 KiB) Viewed 3515 times
G3ZSS
Re: 3D2 Conway Reef
Post by G3ZSS »
Terry, I tried a manual entry for a 10m CW contact but still see the same missing bandslots in the F1 Stats window.
73 Peter G3ZSS
Re: 3D2 Conway Reef
Hi Peter,
Very odd, I even installed WSJT and tried an FT8 contact via UDP and that worked fine also for same call!
Try 'Rescan Award References from the View/Award status/DXCC award 'Maintenance' tab
Re: 3D2 Conway Reef
OK so the issue was none of the other 3D2??? QSO’s were with Conway Reef, they were marked as Fiji with a different DXCC ref, see below. Some pre date Log4OM so probably were imported some years ago.
Probably some other QSO's also recorded as Conway Reef which should not be?
