Upload to Clublog, etc. after ADIF import?
G4AON
Post by G4AON »
When I import QSOs from another instance of Log4OM, then want to update Clublog with them, they are not listed to select... Is there something that needs changing in order to do that?
Dave G4AON
Re: Upload to Clublog, etc. after ADIF import?
Probably the 1st instance uploaded them and marked them as such, did you check the on line sites to see if they are already uploaded?
G4AON
Post by G4AON »
Hi Terry, no they had not been uploaded from the other instance of Log4OM. While I can manually upload to Clublog, etc. it seems to be a missing setting somewhere...
I am currently remotely operating my IC-7300 and keep a log on my laptop temporarily, then export the ADIF and import it into the home PC main logbook.
73 Dave
Then I think the setting shown below is not the same on both PC's
G4AON
Post by G4AON »
Hi Terry
Sorted, I made both log books the same, with sent showing "requested" on both, that works as expected.
73 Dave
:D :D
