When opening program the configuration window opens randomly
W0MS
Post by W0MS »
Seems that about half the time I open LOG4OM the configuration window opens to the Database tap.
The last saved database is listed in the SQLITE window. So I click on save and apply and the program continues as normal. Wondering why this is happening on a random basis. Perhaps I have something set up amiss?
Other than that all seems to run correctly. Any ideas? Thanks
Mike - W0MS
Re: When opening program the configuration window opens randomly
Where is the SQlite database stored?
W0MS
Post by W0MS »
On my C: drive, user folder, document folder, Log4OM folder.
The program opened up normally this morning loading the backup file just fine.
Mike - W0MS
what version number are you using?
W0MS
Post by W0MS »
2.32.1.0
Mike - W0MS
W0MS
Post by W0MS »
I hesitate to download and run updated versions as the program has a tendency to save corrupted JSON files from time to time. Another random issue.
Mike - W0MS
PLease download 3.33.0.0 as this has a fix for this issue caused by Windows update
W0MS wrote: 17 Oct 2024, 17:59 I hesitate to download and run updated versions as the program has a tendency to save corrupted JSON files from time to time. Another random issue.
I have never known that to be the case and there have not been any other reports about such an issue, check your anti virus software is updated
W0MS
Post by W0MS »
OK thanks...
The corrupted profile JSON file issue has a solution so I'll go ahead and do the update.
Mike - W0MS
Anyone that has an issue with a new set up required on starting Log4OM or missing recent QSO's list please contact me by email if you want to test a fix version - EMAIL as QRZ de G4POP
