CHAT Problem
F6FLU
CHAT Problem
Post by F6FLU »
Clearly Log4OM no longer connects to the CHAT
there is a setting somewhere, I have validated the CHAT in the preferences
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: CHAT Problem
Post by F6FLU »
2025-01-14 16_57_44.jpg (23.01 KiB) Viewed 1361 times
Dan - F6FLU
https://F6FLU.org
KE4BCN
Re: CHAT Problem
Post by KE4BCN »
Does not work on mine either.
VK7XX
Re: CHAT Problem
Post by VK7XX »
chat has not worked here for a few days now.. Anyone got a fix ??????
F6FLU
Re: CHAT Problem
Post by F6FLU »
AH OK Thanks for this information
Dan - F6FLU
https://F6FLU.org
Re: CHAT Problem
Has anyone looked at their logfile after attempting a Chat session?
Has that log provided any clues about the Chat session 'connecting' or 'not'?
I would guess that there might be a parameter change at Gridtracker that is causing the Chat session to not properly connect.
The GT folks have made changes before or had a server hiccup that caused issues.
I'm sure both Lele and Terry are aware and checking into this as they can get time in their schedules.
Re: CHAT Problem
When an external service suddenly stops working like Chat, call lookup, clusters etc the diagnosis route should always be .............
1. Have I just updated the software? - If no its unlikely to be the cause
2. Have I changed any settings in the software? - as 1 above
3. Is my anti virus or firwall blocking the external connection? - Turn both off for a short period to see if the external sevices return to normal
4. Has something changed at the external services end, like the PROVIDERS server settings? - If a URL has changed notify the software developer of the new URL
5. Is the server being overloaded due to a contest or simlar?
Please do not immediately blame the software if no chnges or updates have been done, software does not modify itself!
F6FLU
Re: CHAT Problem
Post by F6FLU »
Hi
I have changed ABSOLUTELY nothing and today it works :-)
Dan - F6FLU
https://F6FLU.org
Re: CHAT Problem
That proves it was not a Log4om issue! Most likely a server down at Gridtracker
F6FLU
Re: CHAT Problem
Post by F6FLU »
I didn't understand why GridTracker intervenes in Log4OM's Off Air Message?
Dan - F6FLU
https://F6FLU.org
