band Map and Cluster are different value...
VA2PHK
Post by VA2PHK »
thanks to the whole team for this wonderful program and all the work you do....
can you tell me why my band map does not display all the stations that are found by the cluster.....see my print screen...
probably a bad setting on my part...
thanks in advance ,best regard and
73 `from VA2PHK (Kick) - Canada
band map.png (239.31 KiB) Viewed 661 times
Re: band Map and Cluster are different value...
Kick,
Check your cluster & band map settings at: Settings / Configuration / Cluster
Also check your filter settings for the band map display(s). The filter settings affect 'each' appearance of such.
I happen to use the band map that is integrated into the Main UI as opposed to the one you can move about the screen wherever you need it to be. The filter for each band map only affects "that" band map.
Images below may help.
VA2PHK
Post by VA2PHK »
Thanks Nolan for your quick response
your explanations are very clear..i don't know why but my parameters were completely wrong...
73 ' and best regard....maybe soon on the air....
