Two questions One might be easy !
Log4OM version 2.35.1.0
1: How to enable the Greyline Map ?
2: OmniRig cat
Anyone have a 'programmers' link as to the content of the ini file that V1.2 uses ?
Double click in the cluster does not drive my Yaesu FTDX-10, i.e no frequency change, figure the culprit is in the ini file, I had some problems initially with the VFOA/B switching see viewtopic.php?p=49213#p49213 and ended up using FTDX-10 ini file from V2 omnirig. Anyhow is there information on creating the ini file contents anyplace ?
GU4XEA - Paul C
Two Questions - One might be easy !
Re: Two Questions - One might be easy !
Automatic just select the map in the Program configGU4XEA wrote: 26 Mar 2025, 07:41 Two questions One might be easy !
Edit in Notepad or Wordpad2: OmniRig cat
Thanks Terry #1 was the easy one - found that.
#2 I was looking for info on the structure and specific syntax in use in the ini file and the way that it was intended to work - I don't mind writing the code but its useful to know what to put in, the ini file content isn't exactly self documenting and is somewhat cryptic.
GU4XEA - Paul
GU4XEA - Paul
See the radio user guide for specific codes and use the test program Alex of omnirig provides, it's really easy to edit the ini file in notepadGU4XEA wrote: 26 Mar 2025, 13:15 Thanks Terry #1 was the easy one - found that.
GU4XEA - Paul
Just remember, Paul, if you're going to edit, make sure you run Notepad first as an Administrator and then select the file you wish to edit. Otherwise, it won't save. I'm pretty sure you would knowGU4XEA wrote: 26 Mar 2025, 13:15 Thanks Terry #1 was the easy one - found that.
GU4XEA - Paul
Jim W2KYM
