There is a Sat Mode field which you can place in the log columns. In other programs, that means VU, UV etc rather than the transmission mode, and when I import data from another program, that is what it shows. I wasn't able to successfully edit that within Log4OM. Also, when I go to Options|Expert there is a button for Sat Mode, however nothing happens when I click it. All the other buttons work. Is a file missing? I am using 1.18.0.0.
73s,
Alan
WA4SCA
Sat Mode missing?
Re: Sat Mode missing?
Very strange.
Did you have a file called SATMODELIST.CSV in your settings folder? (settings is accessible from HELP menu)
If not, copy the MODELIST.CSV into SATMODELIST.CSV
the settings button is probably a glitch i'm checking now
There is already a SATMODELIST.CSV present in the settings folder.
Alan
WA4SCA
Alan
WA4SCA
Hi Alan, i'll check values according to the specs.
I've found this list, but doesn't seems complain to ADIF specs.
I'm open to opinions and thoughts.
A
B
J
JL
K
KT
L
R
RA
RK
RT
S
T
U/S
U/V
A
B
J
JL
K
KT
L
R
RA
RK
RT
S
T
U/S
U/V
Let me say that I am NOT an expert on ADI files.
I have used another program which includes the mode in its ADI export, and Log4OM does import it to the Sat Modes column. The part of the file looks like this: USA <SAT_NAME:5>SO-50 <SAT_MODE:2>VU <PFX:2>W5 <State:2>
I can help with the Sat Modes. The old, single letter modes such as A, B, J have been replaced with a new system of two letters which give the uplink and downlink bands. However, people still use the old single letter, especially for older modes which are no longer used. I added some additional modes to your list, and removed the "/" which is sometimes used in text but is not necessary.
This isn't really required for LoTW or eQSL, since you have the frequencies, but is convenient for a quick glance.
73s,
Alan
WA4SCA
A
B
J
JL
K
KT
L
R
RA
RK
RT
S
T
US
UV
VU
LS
VS
73s,
Alan
WA4SCA
A
B
J
JL
K
KT
L
R
RA
RK
RT
S
T
US
UV
VU
LS
VS
Ok, if no one has objections in the next few days i will set this as sat mode list.
