lotw download always 0
When doing a LOTW download I always get that there are 0(zero) matches , but if I look on the lotw page there are new qsl's , wonder what I am doing wrong ?
Re: lotw download always 0
Please let us have the rest of the LOTW download message displayed in the download window
box pops up and says operation complete
Begin ADIF generation request
ADIF request accepted
ADIF document downloaded
ADIF document parsed 0 qso found
Did you use an early start date?
What version of TQSL are you using?
TQSL v2.0.3
I have tries with 1-1-2014
and also todays date 8-12-2014
same results
same results
Go to the Log4om Help menu and select show log
Save the text file and email it to me
DO NOT - I repeat - DO NOT post the text file on the forum
The log file you sent me shows a LOTW response that says you are using the wrong or invalid station location
This has caught a lot of people out, please refer to page 95 of our user guide and in particular the "Important note"
that was a earlier issue , where I could not upload to lotw, I have since got that sorterd out , I can upload , I can upload and download in HRD log book , just cant seem to download in log4om
ok , I just un installed log4om and re installed it , I successfully uploaded to lotw , but still get 0 when tring to do a lotw download .
2014-08-12 18:53:41.7885 INFO: LotwManagement: 0 success; log signed and uploaded and accepted without incident
2014-08-12 18:54:08.2970 ERROR: *** AdifManagement: Error in ADIF import, returning empty log ******* [Function: ImportAdif] System.Exception: File is not in ADIF format
does the above mean anything to you , the first excerpt from the log is a successful upload , and then the second excerpt is what I believe is the reason the download is 0
It's possibly a LOTW issue, I will check this morning
What version of Log4om are you using?
