Network connection to flex 8600
AB7R
Post by AB7R »
I searched and tried the instructions in the manual for setting up Log4OM cat via slicemaster. Slicemaster runs fine but no connection works to l4om. I tried creating a new TCP port for 7820....no luck.
Greg - AB7R
Caldwell, ID
WA2SQQ
Re: Network connection to flex 8600
Post by WA2SQQ »
I suggest you reach out directly to WO2X. He is one of the FRS support staff. He runs an 8600 and I believe with the same software. You can mention my name, he is a good friend.
Bob, WA2SQQ
AB7R
Post by AB7R »
Different logger but yes. Have to wait till Dave returns from hamvention.
Greg
Greg - AB7R
Caldwell, ID
AB7R
Post by AB7R »
I have tried instructions in the manual via slicemaster....no connection.
I have tried various tcp/ip settings....no connection.
I have tried a new com port in smart cat....no connection.
How does log4OM connect to a flex radio?????
Greg - AB7R
Caldwell, ID
All you need for CAT control on the Flex is to connect to 'Smart CAT' from Log4OM
Alternatively use a network connection via Hamlib
