Sorting distance
PB4FUN
Sorting distance
Post by PB4FUN »
The sorting for the field distance in the QSO grid is alpha instead of numerical.
If I sort ascending 1000 should be after 20 and so on.
PB4FUN Meindert; Rig : Icom IC-9100 / Ant: Falcon OUT-250-B @4m AGL; 144 MHz 16 el @ 4m AGL; 70 cm 23 el @ 5 m AGL
Re: Sorting distance
i'll check. Thanks for reporting
PB4FUN
Post by PB4FUN »
In 1.17.1 its still there
Yes, still in list
PB4FUN
Post by PB4FUN »
Difficult or many other priorities ?
PB4FUN wrote:Difficult or many other priorities ?
Many other priorities
But will be there in the next release
Distance is not a "standard" field in visualizations.
This means you have added it to your own visualization.
If you want to fix this issue while waiting for release do the following steps:
Find your configuration folder (..\roaming\LogOm) or use the Help menu -> show configuration folder
Find files called "ViewConfiguration*_user.xml" where * is something like "SmallQSO" or other.
In one of those files, the one where you selected the distance, you will find an XML section containing <ColumnId>Distance</ColumnId>
Find this section and replace <ConfigType>String</ConfigType> with <ConfigType>Decimal</ConfigType>
Report issues :)
Daniele IW3HMH
PB4FUN
Post by PB4FUN »
Nice, its working.
Only I changed it to Integer instead of Decimal.
Yes, i did the same on next release after checking the result
