Sorting distance
PB4FUN
Sorting distance
Post by PB4FUN » 04 Apr 2014, 21:26
The sorting for the field distance in the QSO grid is alpha instead of numerical.
If I sort ascending 1000 should be after 20 and so on.
Re: Sorting distance
Post by IW3HMH » 07 Apr 2014, 15:31
i'll check. Thanks for reporting
PB4FUN
Post by PB4FUN » 29 Apr 2014, 20:38
In 1.17.1 its still there
Post by IW3HMH » 30 Apr 2014, 09:03
Yes, still in list
PB4FUN
Post by PB4FUN » 30 Apr 2014, 18:03
Difficult or many other priorities ?
Post by G4POP » 01 May 2014, 06:45
PB4FUN wrote:Difficult or many other priorities ?
Many other priorities
Post by IW3HMH » 02 May 2014, 09:48
But will be there in the next release
Post by IW3HMH » 05 May 2014, 14:42
Distance is not a "standard" field in visualizations.
This means you have added it to your own visualization.
If you want to fix this issue while waiting for release do the following steps:
Find your configuration folder (..\roaming\LogOm) or use the Help menu -> show configuration folder
Find files called "ViewConfiguration*_user.xml" where * is something like "SmallQSO" or other.
In one of those files, the one where you selected the distance, you will find an XML section containing <ColumnId>Distance</ColumnId>
Find this section and replace <ConfigType>String</ConfigType> with <ConfigType>Decimal</ConfigType>
Report issues :)
Daniele IW3HMH
PB4FUN
Post by PB4FUN » 05 May 2014, 16:59
Nice, its working.
Only I changed it to Integer instead of Decimal.
Post by IW3HMH » 06 May 2014, 08:16
Yes, i did the same on next release after checking the result
