LoTW duplicate upload error
mm0hvu
Post by mm0hvu »
Hi
I hope things are good there
From yesterday after update to latest from previous the following errors are occuring, when submitting LoTW contacts for upload Log4OM (TQSL) continues to see some duplicates and asks if i wish to ignore these, if i do the upload will hang and not upload until I cancel in Task manager or Log4OM, an upload works with Tqsl and HRD Logbook. With total uninstalls of Log4OM and Tqsl and rinstalls both fresh all appdata removed the error still occurs with latest release.
This started with an update to the release yesterday any assistance would be appreciated
Have a great Sunday
73 David
Image 195.jpg (146.77 KiB) Viewed 6029 times
Re: LoTW duplicate upload error
What previous to latest? TQSL, Log4OM or October Windows updater which is know to have problems!
mm0hvu
Post by mm0hvu »
The update yesterday of Log4om to version 1.34, the previous log4om version i had installed was 1.33.
Thank you
David
mm0hvu wrote: 14 Oct 2018, 22:04 The update yesterday of Log4om to version 1.34, the previous log4om version i had installed was 1.33.
Did you install to run as an administrator as in page one of our user guide?
mm0hvu
Post by mm0hvu »
I did install as admin as the guide instructs as i always have.
Please send a support request to Lele by email using his email as shown on QRZ for IW3HMH
mm0hvu
Post by mm0hvu »
I will thank you
Watching
G4VMM
Post by G4VMM »
I'm having a similar problem whereby I can on longer download from LOTW, upload is fine.
From your comments above: "October Windows updater which is know to have problems!"
Windows did an update 12th October and problem has started since then.
When I try to download I get this far:
Begin ADIF generation request
Login G4VMM
qso_qslsince 2018-10-11
Followed by pop-up box, "operation completed"
I've checked my external logs, lotw settings, and they are correct ID, password etc.
Any suggestions?
Regards Steve
Turn on trace mode in help/debug then attempt another download
Save the text file and email it to me at the email address shown on QRZ
DO NOT POST IT ON FORUM
