V2 Wrong Frequency report to QRZ
W5RDL
Post by W5RDL »
V2.1.0.0 is reporting the wrong frequency in QRZ. When I log a contact on 75m 3.828 LSB it saves in the log4om log correctly but it's reported as 3.820 on QRZ. com log.
Myself and KG5ANO are having the same problem.
Re: V2 Wrong Frequency report to QRZ
W5RDL wrote: 24 Jan 2020, 01:08 V2 is reporting the wrong frequency in QRZ. When I log a contact on 75m 3.828 LSB it saves in the log4om log correctly but it's reported as 3.820 on QRZ. com log.
Rix,
Can you please establish a support ticket with attachments that will help ID what you have noted?
In V2 you can also go to Help/Open Log File and view all the actions taken by V2. You can scroll through there and maybe note any anomalies that will help dig into this.
KI5IO wrote: 24 Jan 2020, 01:24
Rix,
I think you will find that it is QRZ rounding off the frequency we send the exact frequency as in the logbook!
G4POP wrote: 24 Jan 2020, 04:02
8 KHZ Terry?
Mine rounds to 1 KHZ in QRZ.
kd0zv wrote: 24 Jan 2020, 11:52
8 KHZ Terry?
I missed that it was 8Khz it round the Hz as in my image below.
Does this happen every time?
g0ddj
Post by g0ddj »
I am having the same problem, rounds the last digit to zero.
HB9VQQ
Post by HB9VQQ »
That is how QRZ.com Log works. Resolution set to kHz, won't show Hz.
Flex 6600 - Spiderbeam
W5RDL
Post by W5RDL »
That’s not how QRZ works because it works fine with version 1 of LOG4OM and is not working with version 2. I just went back to using version 1 till the problem is resolved.
W5RDL wrote: 28 Jan 2020, 18:52 That’s not how QRZ works because it works fine with version 1 of LOG4OM and is not working with version 2. I just went back to using version 1 till the problem is resolved.
Nether of you answered my question "does it happen all the time" like every qso
W5RDL
Post by W5RDL »
Yes it happens with every QSO.
