V2.1.0.0 is reporting the wrong frequency in QRZ. When I log a contact on 75m 3.828 LSB it saves in the log4om log correctly but it's reported as 3.820 on QRZ. com log.
Myself and KG5ANO are having the same problem.
V2 Wrong Frequency report to QRZ
Re: V2 Wrong Frequency report to QRZ
Rix,W5RDL wrote: 24 Jan 2020, 01:08 V2 is reporting the wrong frequency in QRZ. When I log a contact on 75m 3.828 LSB it saves in the log4om log correctly but it's reported as 3.820 on QRZ. com log.
Can you please establish a support ticket with attachments that will help ID what you have noted?
In V2 you can also go to Help/Open Log File and view all the actions taken by V2. You can scroll through there and maybe note any anomalies that will help dig into this.
I think you will find that it is QRZ rounding off the frequency we send the exact frequency as in the logbook!KI5IO wrote: 24 Jan 2020, 01:24Rix,W5RDL wrote: 24 Jan 2020, 01:08 V2 is reporting the wrong frequency in QRZ. When I log a contact on 75m 3.828 LSB it saves in the log4om log correctly but it's reported as 3.820 on QRZ. com log.
8 KHZ Terry?G4POP wrote: 24 Jan 2020, 04:02
Mine rounds to 1 KHZ in QRZ.
I missed that it was 8Khz it round the Hz as in my image below.
Does this happen every time?
I am having the same problem, rounds the last digit to zero.
That is how QRZ.com Log works. Resolution set to kHz, won't show Hz.
Flex 6600 - Spiderbeam
That’s not how QRZ works because it works fine with version 1 of LOG4OM and is not working with version 2. I just went back to using version 1 till the problem is resolved.
Nether of you answered my question "does it happen all the time" like every qsoW5RDL wrote: 28 Jan 2020, 18:52 That’s not how QRZ works because it works fine with version 1 of LOG4OM and is not working with version 2. I just went back to using version 1 till the problem is resolved.
Yes it happens with every QSO.
