V2 Wrong Frequency report to QRZ
HB9VQQ
Re: V2 Wrong Frequency report to QRZ
Post by HB9VQQ »
That’s not how QRZ works because it works fine with version 1 of LOG4OM and is not working with version 2. I just went back to using version 1 till the problem is resolved.
Can you show where QRZ.com shows Hz resolution ?
All I see is rounded to kHz
again
That is how QRZ.com Log works. Resolution set to kHz, won't show Hz.
Flex 6600 - Spiderbeam
W5RDL
Post by W5RDL »
I guess the original issue was miss understood. When I log a contact with say 14.255 in LOG4OM in version 1 it’s received in QRZ as 14.255
Now when I’m using the same frequency in LOG4OM Version 2 it’s received in QRZ as 14.250 so hows it QRZ’s fault for this error.
Don’t get me wrong I love LOG4OM over all other logging problems. I was just pointing out a small error in frequency being seen or received in QRZ with the new Version 2.
HB9VQQ
Post by HB9VQQ »
Ok got it , I think there is another thread with the same issue
https://forum.log4om.com/viewtopic.php?f=31&t=4602
g0ddj
Post by g0ddj »
G4POP wrote: 28 Jan 2020, 18:55
W5RDL wrote: 28 Jan 2020, 18:52 That’s not how QRZ works because it works fine with version 1 of LOG4OM and is not working with version 2. I just went back to using version 1 till the problem is resolved.
Nether of you answered my question "does it happen all the time" like every qso
Yes it is happening all the time with every contact. no problem with V1 though on QRZ.com
HB9VQQ
Post by HB9VQQ »
Trying to identifiy the root cause of this issue.
Logged in Log4OM like this
That's the log on QRZ.com
Just for a test I deleted this QSO with TK5MH from QRZ.com which initially was uploaded automatically from Log4OM.
Then I manually exported just this QSO from Log4OM to an ADIF file. Content looks ok, frequency is still correct
...<FREQ:5>14.085....
Then I manually imported this ADIF file on QRZ.com, again showing the wrong frequency.
After that I imported the same ADIF file into HRD Logbook, showing wrong frequency.
Roland
HB9VQQ
Post by HB9VQQ »
After some research I found changing the Log4OM generated ADIF file from
<FREQ:5>14.085
to
<FREQ:6>14.085
and importing the file on QRZ.com the frequency is correct
Each ADIF record contains one or more fields in the form of <keyword:n>value, where n is the number of characters in the data value. So a value of 5 is wrong and would represent 14.08. N needs to be 6.
If you are going to log VHF/UHF freq. it needs to be 7 and so on....
Roland
g0ddj
Post by g0ddj »
Nice to see that this problem has been resolved, thanks.
