i have log4omV2 2.3.0.0 problems
ES2HV
problem
Re: problem
the incoming call flag is missing and does not show the grid on the map. Previous version showed log4omv2 2.2.0.0
ES2HV
ES2HV
Re: problem
Works for meviki wrote: 05 Feb 2020, 07:43 the incoming call flag is missing and does not show the grid on the map. Previous version showed log4omv2 2.2.0.0
ES2HV
What are your Info Provider settings ?
Flex 6600 - Spiderbeam
Re: problem
Suggest you check your on line lookup services and update the country file because it's working perfectly with that call sign here
Re: problem
https://www.qrz.com/page/subscriptions.html
If you don't wanna pay for qrz.com sub then change your primary to HAMQTH
Re: problem
Running program - I restarted "run as administrator" and then started to function ... for TNX suggestions ...
ES2HV
ES2HV
Re: problem
I am not running Log4OM with administrator privileges and all works fine....
Seems something is strange with your setup.
Re: problem
Looks like you are running QRZ as primary and I do not see you have a subscription on your QRZ.com page.
