If I make a 60 meter contact the band does not show up in the EDIT QSO window but does get displayed in the
Recent QSO window. If I try to add it manually it will not stay. This only occurs with 60 meters.
60 meter band not logging properly
Mike Burton
xe2/n6kzb
xe2/n6kzb
Re: 60 meter band not logging properly
You don't show the frequency in your screen shot, is there one?
Yes freq is captured in all instances..
Mike Burton
xe2/n6kzb
xe2/n6kzb
I can confirm.
Band does not show up for me either.
Oddly enough you can see 60m flicker in the band location as the window opens but is blank after.
- 2020-02-28_15-12-21.gif (16.58 KiB) Viewed 7532 times
I have also seen a similar issue when logging from WSJT on 60m.
In my case the log entry looks good and the band info shown correct but if you go to edit the qso record
the band info (both TX & RX) is blank.
Doing a manual qso entry on 60m directly seems to work OK, all other band qsos' logged from WSJT are also
not a problem.
Log4OM 2.3.0.0
WSJT v2.1.2
not a problem.
Log4OM 2.3.0.0
WSJT v2.1.2
Graham
M0GWC
M0GWC
In my case information is:
Callsign: M0GWC
IARU: 1
Station Country: England
ITU: 27
CQ: 14
Callsign: M0GWC
IARU: 1
ITU: 27
CQ: 14
Graham
M0GWC
M0GWC
Was hoping to see the fix in the latest release, but not yet.
Perhaps next release?
Mike Burton
xe2/n6kzb
xe2/n6kzb
Is a fix being considered?
As you can see by the posts, I am not the only one with this issue.
Thanks and enjoying Log4OM.
Adios
Adios
Mike Burton
xe2/n6kzb
xe2/n6kzb
