Adding “Distance” value
IU4MTO
Re: Adding “Distance” value
Post by IU4MTO »
DF5WW wrote: 28 Feb 2020, 14:41 Hi Fabrizio & Graeme ....
i can report only what happens with the latest Alpha release so please check out for the next official
release. Think a lot of issues are solved.
Just upgraded to 2.4.0.0 and ... the issue is solved.
Regardless if it is WWL with 4 or 6 digits, not it calculate the distance.
Only issue... in my log about 400 entries have distance to 0.
If I open the edit window, and I do not edit nothing but just save, the distance is calculated !
Only problem I have to open and save all the QSO with distance 0....
73 de IU4MTO Fabrizio
F5PEQ
Post by F5PEQ »
Hello All,
I just upgraded to version 2.4.0.0. You did a great job . Thanks a lot.
Like Fabrizio, I have also hundreds of QSO's without distance : is there a way to compute them all in one go ?
73 de Patrice F5PEQ
HB9ETR
Post by HB9ETR »
curious as to why the distances now show a decimal and, if i save a previous input from V1 (in this case), i get a different distance.
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.33.0.0
Win10 i5-11400 @ 2.60GHz
HB9ETR wrote: 14 Mar 2020, 11:31 curious as to why the distances now show a decimal and, if i save a previous input from V1 (in this case), i get a different distance.
Because qso's logged in V2 have distance calculated slightly differently but imported QSO's are not subject to these calculations and are just saved exactly as the data was saved in V1 and as received in the ADIF file.
PE5TT
Post by PE5TT »
Since V2 i don't see any distance between me and DX station, this used to be calculated even if there was no locator entered. (probably mid country to mid country)
Now the Distance colom is empty, also in V1 i could recalculate the distances in the "massive QSO update" window, for example when QSO where imported, don't see this option anymore.
no distance.png (61.72 KiB) Viewed 3776 times
