Version 2.10.0.0 - Double click on Bandmap not working - SOLVED
F4HGU
Re: Version 2.10.0.0 - Double click on Bandmap not working
Post by F4HGU »
F6FLU wrote: 22 Nov 2020, 17:07 Salut Pat
what worries me in your omnirig settings :
For me DTR and RTS have to set "Low" not "High"
AND
You have the same value for the Polling interval and the Timeout Interval
For me the Timeout MUST be higher than the Polling ...
I try, thanks Daniel !
F4HGU
Post by F4HGU »
Daniel, you are the Boss !! ;) Thank you, it works !!
Terry, thank you very much for your support. I love this software ! :)
The issue is fixed with the following parameters. If that could help somebody else.
F6FLU
Re: Version 2.10.0.0 - Double click on Bandmap not working - SOLVED
Post by F6FLU »
Thanks :) ;) ;)
Dan - F6FLU
https://F6FLU.org
ON7WF
Post by ON7WF »
Hello Dan,
I also had a very slow working log4om V2 and version 2.10 was a real catastrophy! So I started digging around and came across your topic. I did a clean install of log4om V2 and omni-rig and I applied your last posted omni-rig settings and what a revelation, log4om V2 is finally working at an acceptable speed. :D
Thanks a lot.
ON7WF - Wil
F6FLU
Post by F6FLU »
Hi
very happy to have been helpful
For some explanations :
DTR means Data Terminal Ready (use for CW)
and
RTS means Request To Send (use for PTT)
Soon all this help and detailed explanations in French on my site ....Wait & See
Dan - F6FLU
https://F6FLU.org
ON7KZ
Re: Version 2.10.0.0 - Double click on Bandmap not working - NOT solved
Post by ON7KZ »
Same issue here on my ftdx101 it happens always during the time from data lookup, so have put back 2.9 version
73 Luc, ON7KZ
ON7KZ wrote: 24 Nov 2020, 13:27 Same issue here on my ftdx101, so have put back 2.9 version
73 Luc, ON7KZ
Did you try the fix above?
ON7KZ
Post by ON7KZ »
Yes,
I have trying it all, its happens during time "data lookup"
73 Luc
