PSTRotator
F6FLU
PSTRotator
Post by F6FLU »
I can't use PSTRotator in "automatic" mode, if I enter a call in Log4OM I would like to turn my antenna towards this call, I tried to click on the "azimuth" field at the top from the input screen but nothing happens, if I type the call in PSKRotator, the rotor turns well to position itself in the right direction
I think we need to configure something
but obviously Log4OM does not pass the call to PSTRotator
of course in Log4OM I have correctly configured the UDP OUTBOUND # 12040 port but I think that it is in PSTRotator that it is necessary to modify in the settings
would you have some details for me on the subject?
Thanks and 73
Dan - F6FLU
https://F6FLU.org
CT1BXX
Re: PSTRotator
Post by CT1BXX »
Hi Dan,
I am not at home now to describe in detail what I have.
But two things to remember:
1- You need to inform PSTrotator what log you are using
2 - In Pstrotator you need selecet "Tracking" ( main window)
You always need to click in Azimuth field in Log4om to send the command to PSTrotator.
I have it working fine and also my remote antenna swicth via PSTrotator.
Hope it can help.
Have a nice day.
73 Manuel Fernando CT1BXX
F6FLU
Re: PSTRotator
Post by F6FLU »
Thanks Manuel
Yes I have set Log4OM to Tracker menu from PSTRotator
PSTRotator Tracker.jpg (65.21 KiB) Viewed 4867 times
Yes I selected "Tracking" in the PSTRotator
PstRotator interface.jpg (68.99 KiB) Viewed 4867 times
But if I write a call into Log4OM and click on Azimut Field nothing is happening ...
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: PSTRotator
Post by F6FLU »
Can nobody help me on this topic?
Dan - F6FLU
https://F6FLU.org
SQ5TDZ
Re: PSTRotator
Post by SQ5TDZ »
is everything ok here ?
EDIT : the firewall does not block the program ?
Andrew.....SQ5TDZ
F6FLU
Re: PSTRotator
Post by F6FLU »
I found the problem;
obviously there was a blank character in the port number.
Is there no verification that this port number is numeric?
Thanks to everyone who tried to help me
Dan - F6FLU
https://F6FLU.org
SQ5TDZ
Re: PSTRotator
Post by SQ5TDZ »
Andrew.....SQ5TDZ
ph2m
Re: PSTRotator
Post by ph2m »
I have the same problem for the last few months, running always latest versions of Log4OM (v2) & PstRotatorAz.
Portnumber 12040 in both programmes, PstRotatorAz works O.K. when selecting a beaming, but nothing happens when clicking 'Azimuth' (e.g. showing 156 deg.) and the beam/rotator is pointing e.g. 188 deg.
I hope someone can help to get this working again...
73 de Frank PH2M
