I am using Log4OM NextGen ver 2.17.0.0. I am unable to setup Contests using the Contest->Contest Settings option. In the Contest drop down no contest names appear. I even reinstalled Log4OM but issue persists. When I use resource editor I am able to see the default list of contests.
Screen images are attached. I have never faced this issue earlier.
Contest List NOT displayed
- Log4OM_NoContest.jpg (53.92 KiB) Viewed 1530 times
- Log4OM_ContestList.jpg (155.51 KiB) Viewed 1530 times
Re: Contest List NOT displayed
Is the program installed in the default folders that automatically are offered during the install?
Are you running the portable or the installed version?
Dis the list show in the past or is this the first time you have tried to use it?
Is Log4OM being run as an administrator?
Yes. I am using Log4OM for the past 18 odd months. So when a new version is released I just download and install the same. I run the installer in "Run as Administrator" mode.Is the program installed in the default folders that automatically are offered during the install?
I am using the installed version.Are you running the portable or the installed version?
I had used the contest configuration options earlier. I could chose the contest name in the drop down and then set the parameters like date of operation, serial numbers etc. Earlier I used to edit the contests.csv file using Notepad++. Even after doing that the contests used to appear in the drop down.Dis the list show in the past or is this the first time you have tried to use it?
No. But since you mentioned it, I also tried to run the same as administrator. The results are the same.Is Log4OM being run as an administrator?
Please let me know if you need any more information. Thanks in advance!
Ok
You will find a contest_user file in your roaming/lo4om folder delete or rename it and restart Log4om
Thank you!! This worked.G4POP wrote: 30 Oct 2021, 17:43 You will find a contest_user file in your roaming/lo4om folder delete or rename it and restart Log4om
