I'm entering the callsign A60EXPO/2, a UAE special event callsign, and it correctly displays UAE as the country until I type in the /2 suffix. This changes the country to Botsawana. It seems that adding a number suffix changes the country. Actually adding a valid country suffix also changes the country. Is this correct?
A60EXPO = Bahrain
A60EXPO/2 = Botswana
A60EXPO/EI = Ireland
A60EXPO/2/A6 = Bahrain
Incorrect country displayed
Re: Incorrect country displayed
This issue has already been posted at this thread here on the Log4OM V2 Forum ...
https://forum.log4om.com/viewtopic.php?f=31&t=7172
And, my tests this morning seem to show them all resolving to UAE properly.KI5IO wrote: 02 Jan 2022, 14:47 This issue has already been posted at this thread here on the Log4OM V2 Forum ...
Hi Nolan,
still wondering that is works at your side. Running latest Alpha and have updated all of the Resources
but the result ist Botswana if i fill in A60EXPO/2 .... After Resources update i have restarted.
Juergen,
I was using V2.18.0.0 and just updated to V2.18.1.0 to verify and the A60EXPO/2 is resolving correctly for me.
Likely due to my Info Provider settings. See screen clip below.
- InfoProviders-medium.JPG (55.94 KiB) Viewed 1718 times
Juergen,
Just did some more testing. I disable my QRZ external search and made HAMQTH as prime for external Info Provider.
Then I get the "non-UAE" countries.
Information at HAMQTH is not updated it appears.
That could be possible. I have clublog in my provider settings and in thise case my settings
are different from yours. Will give it a try in the next days. Tomorrow the QRL starting again ...
By the way, i don´t have QRZ active, only HamQTH. I´m not a QRZ subscriber ...
Juergen,DF5WW wrote: 02 Jan 2022, 18:51 That could be possible. I have clublog in my provider settings and in thise case my settings
are different from yours. Will give it a try in the next days. Tomorrow the QRL starting again ...![]()
By the way, i don´t have QRZ active, only HamQTH. I´m not a QRZ subscriber ...![]()
I just tested again with QRZ and HAMQTH "disabled" and having Clublog active.
I did NOT get the UAE.
Maybe only QRZ is correct with this one ???
