Hi My send spot is not working . I have had no problem until the start of this week.
The Green button next to the globe is ok and the cluster and cluster server are green.
When I click on the orange spot button the LOG40M 2V at top of page goes black and the dropdown box does not
appear . Any suggestions as to how to fix ???
thanks John
Hi Terry ,
Still having this problem. I do note that in cluster management it says im connected which is greyed out and I have one pri active server but I dont see anything in Known servers. See attachment.
Also is the Export ADIF function been disabled as I dont seem to be able to save a file to .adif
Thank you and appreciate your reply
Merry Christmas and Happy new Year John
Screenshot 2022-12-22 162745.jpg (71.96 KiB) Viewed 1311 times
ZL3TRR wrote: 22 Dec 2022, 03:32
I do note that in cluster management it says I am connected which is greyed out and I have one pri active server but I dont see anything in Known servers. See attachment.
Make sure this box is checked in config and restart Log4OM then you should have a full list. Try another cluster ansd see if you can send spots
This is probably a Widows security issue because its working fine, however where EXACTLY are you trying to save an ADIF file from in Log4OM?
Hi Terry ,
Thanks for the quick reply.
Clicking on the show stable cluster box fixed the known servers search . Thank You
Re .adif file I was trying to save from File/Export ADIF. I have always kept a spare copy of the log in ADIF incase my computer crashes.
Re my original question as to Not being able to send spots what do you suggest or do I live with it?
Ver 2.25.0.0
When I have a callsign in the callsign box and info populates in boxes and I press the Orange icon the second screen does not come up??
Thanks John
