re-adding bands
Re: re-adding bands
Hello, my 2 cents:
You should not modify the original file but duplicate it and rename the duplicate file with the name "bandlist_user.txt"
You modify what you want in this user file and at startup, Log4OM will take into account this user file instead of the original file. I attach the original file. Best wishes
Hello, my 2 cents:
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: re-adding bands
Just highlight the user file in the resources editor and click on trash can icon - this deletes the user fileyo2oxd wrote: 06 Nov 2022, 08:42 Hi,
I removed a number of bands from log4om because I didn't have antenna for them. I edited the file bandlist.txt in resource editor and restarted the program. Now that I want to add back a band, I went and edited the file again, restarted, but the band doesn't reappear. It is not showing in the map view or in the qso entry window. If I insert the rx/tx frequency of that qso it will appear in the band drop-down, but only for that qso. How do I reset the bands?
Now select the default file from left window and edit - save file when finished editing
Re: re-adding bands
Thanks!
- image0.jpeg (182.96 KiB) Viewed 966 times
Re: re-adding bands
Settings/program config and I think user settings check the band boxes required
Re: re-adding bands
Here 'tis ...
- config-userprefs-medium.JPG (73.12 KiB) Viewed 959 times
