re-adding bands
yo2oxd
re-adding bands
Post by yo2oxd »
Thanks!
F6FLU
Re: re-adding bands
Post by F6FLU »
Hello, my 2 cents:
You should not modify the original file but duplicate it and rename the duplicate file with the name "bandlist_user.txt"
You modify what you want in this user file and at startup, Log4OM will take into account this user file instead of the original file. I attach the original file. Best wishes
bandlist.zip
(214 Bytes) Downloaded 76 times
Dan - F6FLU
https://F6FLU.org
Re: re-adding bands
yo2oxd wrote: 06 Nov 2022, 08:42 Hi,
I removed a number of bands from log4om because I didn't have antenna for them. I edited the file bandlist.txt in resource editor and restarted the program. Now that I want to add back a band, I went and edited the file again, restarted, but the band doesn't reappear. It is not showing in the map view or in the qso entry window. If I insert the rx/tx frequency of that qso it will appear in the band drop-down, but only for that qso. How do I reset the bands?
Just highlight the user file in the resources editor and click on trash can icon - this deletes the user file
Now select the default file from left window and edit - save file when finished editing
yo2oxd
Re: re-adding bands
Post by yo2oxd »
Thanks!
yo2oxd
Re: re-adding bands
Post by yo2oxd »
image attached
yo2oxd
Re: re-adding bands
Post by yo2oxd »
another image
yo2oxd
Re: re-adding bands
Post by yo2oxd »
bandlist_user file
image0 (1).jpeg (64.59 KiB) Viewed 969 times
Re: re-adding bands
Settings/program config and I think user settings check the band boxes required
yo2oxd
Re: re-adding bands
Post by yo2oxd »
thanks!
Re: re-adding bands
yo2oxd wrote: 06 Nov 2022, 15:11
G4POP wrote: 06 Nov 2022, 14:22 Settings/program config and I think user settings check the band boxes required
I cannot find a user settings location with band boxes to check in the program config?!
Here 'tis ...
