Hello, for about a couple of months when I log one QSO this are doubled on Log4OM.
Differences on the two QSOs are the time, 30sec of difference.
I use the Log4OM with JTalert and WSJT-X.
Log4OM is the latest revision.
How I can resolve the error?
Thanks, Camillo
Double on logging
Re: Double on logging
Ypu logging from both JTAlert and WSJT, probably using the ADIF monitoe - Stop the WSJT logging
Hi Mr. Terry, thanks for the reply, I test to find the option on wsjt-x menu.
See you..
See you..
73s, Camillo
Just stop whatever logging connection you have to WSJT in Log4omiz6gvc wrote: 21 Oct 2023, 08:45 Hi Mr. Terry, thanks for the reply, I test to find the option on wsjt-x menu.
See you..
Hello Mr Terry, this is my situation on Log4OM:
This on WSJT-X:
This on JTAlert:
73s, Camillo
Also I had find this on the net, what is my situation?
https://www.log4om.com/l4ong/usermanual ... ith_JT.pdf
73s, Camillo
In JTAlert/Last QSO ADIF
UNCHECK all four check boxes
Your logging twice from JTAlert, you only need to use the specific JTAlert Log4OM menu and log to SQLite file
