Double on logging
iz6gvc
Double on logging
Post by iz6gvc »
Hello, for about a couple of months when I log one QSO this are doubled on Log4OM.
Differences on the two QSOs are the time, 30sec of difference.
I use the Log4OM with JTalert and WSJT-X.
Log4OM is the latest revision.
How I can resolve the error?
Thanks, Camillo
73s, Camillo
Re: Double on logging
Ypu logging from both JTAlert and WSJT, probably using the ADIF monitoe - Stop the WSJT logging
iz6gvc
Post by iz6gvc »
Hi Mr. Terry, thanks for the reply, I test to find the option on wsjt-x menu.
See you..
73s, Camillo
iz6gvc wrote: 21 Oct 2023, 08:45 Hi Mr. Terry, thanks for the reply, I test to find the option on wsjt-x menu.
See you..
Just stop whatever logging connection you have to WSJT in Log4om
iz6gvc
Post by iz6gvc »
Hello Mr Terry, this is my situation on Log4OM:
UDP Connections.png (19.56 KiB) Viewed 6107 times
This on WSJT-X:
UDP WSJT-X.png (27.29 KiB) Viewed 6107 times
This on JTAlert:
Logging JTAlert 1.png (71.49 KiB) Viewed 6107 times
73s, Camillo
iz6gvc
Post by iz6gvc »
Continue JTAlert Connections:
Logging JTAlert 2.png (55.48 KiB) Viewed 6108 times
73s, Camillo
iz6gvc
Post by iz6gvc »
What is the connection that I can disable?
73s, Camillo
iz6gvc
Post by iz6gvc »
Also I had find this on the net, what is my situation?
https://www.log4om.com/l4ong/usermanual ... ith_JT.pdf
73s, Camillo
In JTAlert/Last QSO ADIF
UNCHECK all four check boxes
Your logging twice from JTAlert, you only need to use the specific JTAlert Log4OM menu and log to SQLite file
iz6gvc
Post by iz6gvc »
Hello Mr Terry, no changes are made with your suggestion.
No Change Double Logging.png (61.77 KiB) Viewed 6090 times
73s, Camillo
