Double on logging
Re: Double on logging
In Log4OM show me the ADIF monitor menu in connctions
iz6gvc
Post by iz6gvc »
Hope are this:
ADIF Monitor.png (42.9 KiB) Viewed 6035 times
73s, Camillo
What are the WSJT logging/reporting settings?
iz6gvc
Post by iz6gvc »
Were I can find this info?
73s, Camillo
Wsjt configuration menu!
iz6gvc
Post by iz6gvc »
Hello Mr. Terry, sorry for my absence.
I have some trouble on my family, soon as possibile I male a report for your suggestions!
73s, Camillo
iz6gvc
Post by iz6gvc »
Hello Mr. Terry this is the menù:
WSJT-X Reporting.png (26.81 KiB) Viewed 5833 times
73s, Camillo
iz6gvc
Post by iz6gvc »
Hello Mr. Terry the photo I posted doesn't answer your question?
Regards
73s, Camillo
Sorry for delay I have not been well
No it does not answere reason but somewhere your sending QSO twice to Log4OM, probably from WSJT as in your last screenshot, but also JTAlert or Gridtracker?
To clear the dupes in the log
1. Export an ADIF
2. Create a new empty database
3. Import the ADIF that you exported but in the import window set 'Duplicate threshold' to 60 sec
iz6gvc
Post by iz6gvc »
Hello Mr Terry,
thanks for the suggestion but thw trouble remain.
If I reload the adif with the impostation that you suggested the problem of the dupes remain because remain two applications that send the same infos.
Regards
73s, Camillo
