When i enter a call sign the lookup works and populates the users data.
I updated today to 2.32 from 2.31 and this stopped working.
I tried on my field laptop and tested it worked before I did the upgrade and it worked, then did the upgrade and it stopped working.
I tried changing it to look up from qrzcq instead of qrz but this made no difference.
Any ideas?
Many thanks
Call sgin lookups not working on 2.32
Re: Call sgin lookups not working on 2.32
James,M0LZN wrote: 15 Mar 2024, 12:33 Hello,
Any ideas?
Many thanks
I just installed the same/latest release as you have noted and the Main UI lookups are working FB here.
Maybe try a re-installation of the new release?
- Main-UI.png (121.41 KiB) Viewed 2110 times
Just tried that. First time a install on top and same issue.
2dn time removed log4om and removed the folder from c:\user\m0lzn\appdata\roaming\log4om and the did a fresh install .
Same issue.
It does flash up the data lookup in the call sign.
Checking the log viewer it does this:
Same issue.
Code: Select all
14:50:59.696 Info: [dje_zMHKFRAFDU5792C44FYSWD_ejd] : [QRZCOM] Search start on M0LZN (originally M0LZN)
14:51:00.135 Info: * [dje_zMHKFRAFDU5792C44FYSWD_ejd][439 ms] : [QRZCOM] Search finished on M0LZN (originally M0LZN)
14:51:00.135 Error: [dje_zXA927ZKYSCNH7YV5PR8PC2ULM66T5Z89RS_ejd][MoveNext] : [EXCEPTION] The given key was not present in the dictionary.
Your only a 'Ham memnber. not an XML subscriber to QRZ so you wont get the lookupM0LZN wrote: 15 Mar 2024, 12:33 Hello,
Any ideas?
Many thanks
If you dont want to pay for QRZ try HamQTH which you can register for free lookups
i haven't been a xml member of QRZ for a few months so wonder why it was working on version 2.31 this morning and updating to 2.232 stopped it working.
Also qrz lookups are working in other apps .
removed 2.32 and installed 2.31 and its working fine.
I have the same experience with the 2.32 version. I am not a QRZ subscriber but i get the green sign when i fill in the QRZ login and password under "info providers". I am using Log4om for several years now and never had a problem with it.
I re-installed the older version and everything works fine again.
Hope this wil be fixed soon in a newer version.
New version available is 2.32.1.0 please check.
Tried downloading the new version 2.32.1.0. on Windows 11 laptop. Windows Defender reports there's a virus detected and aborts the download.....
Windows Defender detects: Trojan:Script/Wacatac.B!ml
