HI,
I tried to search the forum for this topic, but it keeps telling me my search word is too common. Oh well.
Log4OM has been working fine for a few years and suddenly THIS happens: Whenever I select (double click on) a station I want to work from the cluster, and they are listed as "DIGITAL", the program properly switches to the frequency, but it puts my IC-7300 into RTTY-R instead of USB-DATA. Also if the station is listed as "PHONE" it switches me to the freq, puts me in the proper mode (USB/LSB (so far so good)) but changes my IF filter to "FILter 2".
I haven't changed anything (as far as I know). Since this is a new computer, I have been getting all of my programs to work as they did on the old one. I was working on FLDigi the other day, but it had nothing to do with Log4OM. I don't use FLDigi with Log4OM other than sending qso data over, but I haven't made a QSO with FLDigi since I got the new computer.
Thanks for any help es 73,
Steve - N6RSH
Mode Change from Cluster
Re: Mode Change from Cluster
Log4OM version number?
Omnirig or Hamlib and what version numbers?
USB cable connection or Remote on back of rig?
Omnirig Version 1.2
Both cables from radio to computer (USB and CI-V)
Thanks,
Steve
Thanks,
Steve
I have hopefully attached a screen shot of the CAT Management tab in Configurations. Which setting should I change?
- Log4OM CAT Management.jpg (146.82 KiB) Viewed 1440 times
It says "Switch to Digital" already. What am I missing?
Here is my Omnirig panel. I WAS using Hamlib on the old computer. I started using Omnirig on THIS computer a couple of months ago. I was working fine until one day rescently. I just turned on the computer and this started happening. I mean I can manually switch the mode back to USB-DATA but selecting a station in the cluster should put me in the proper mode. I DOES for any other mode except FT8/4.
1) Is there a setting in the Cluster that needs to be changed?
2) Is there a .ini or registry file that needs to be checked?
3) Would it be better to use Hamlib?
4) Do I ask too many question for a guy from Nebraska?
Thanks,
Steve N6RSH
Thanks,
Steve N6RSH
- Screenshot 2024-10-07 Log4OM Omnirig.jpg (23.08 KiB) Viewed 1071 times
Try changing the setting that I referred to from FT8 to something else!
Steve,
You might could also try the IC-7300-DATA ini from the Omni-Rig Settings.
They provide the different ini's due to programming options from what I've seen.
Thanks, Nolan
That did the trick. Changing to IC-7300-DATA works. I can now go to ANY mode from the cluster now. I don't know how it changed, but I am getting old and probably don't remember if/when I did it.
Thanks to ALL who chimed in.
Steve N6RSH
Steve N6RSH
